I'm feeling like an idiot as this has to be something simple, but I just do not see it.
Entry/Exit 1 and 2 make all kinds of sense on the face of it. And on entry it is easy to see how you identify which is a "2" time.
But exit -- what should happen?
I set up my garage door to Exit2, then set both entry and exit 1 to 60 seconds, and entry and exit 2 to 180 seconds.
Standing in the house, I arm the system "exit", it starts counting down at 60.
So first question -- on exit how does it know to use Exit 2, since there is no keypad association. I assumed it would switch to the longer time when I violated an Exit 2 zone.
So I go out the inner garage door (I've tried setting it to both interior/following, exit1 and exit 2) and open it -- still countdown is running from 60. Then I open the garage door -- count down continues from 60 and arms at zero.
How do I get it to honor the Exit 2 time?
When I come back in same thing -- it shows a countdown from 60 is running. Although in that case I swear it restarted when I opened the interior door, and I do NOT have the "Restart exit timers" checked on the area.
I really want to have the garage door as force arm also (since it is frequently up when someone wants to leave), and that is even more strange -- one opening it instead of a 3 minute count, it just says "force" and doesn't start a count at all until I open the inner door.
What am I missing? I just want basic force-arm functionality with a longer count for the garage door, not all the fancy rules I've read about elsewhere.
Is there some magic to getting Exit 2 time to work other than doing it in the zone definition as 02=Burg Entry/Exit 2?
