I'm designing an M1G upgrade of my existing Westec 5000 system. Initially I'm just installing a functional replacement for the W5K but will also engineer ample headroom for expansion.
I'm a bit confused about the M1G specs on 12VDC current capacity. I see number such as a 2500mA power supply, but 1000 mA continuous. I'm assuming this to mean that I can draw 2500mA in alarm conditions and 1000mA steady state. Correct?
I also see words in the installation docs that the VAUX, SAUX, VKP, and J16 total current is 1000mA. Correct? Is this in peak/alarm state condition or steady state? What about the Zone16 supply to a set of 2-wire smoke detectors? Where is this in the current budget? What is the current limit on Zone16 for 2-wire smoke det's.?
Also, in the 1000mA continuous, is the M1 panel consumption in this number? Obviously when the panel is in alarm it will draw additional current to power the speakers and/or siren. Are these numbers specs somewhere? Are they just lumped in the 2500mA number?
Is there a complete spec somewhere? Maybe it's somewhere obvious, but I haven't seen it.
I need to assemble a current budget for sensors, keypads, ex panders, etc. I fully understand the specs on the devices, but I don't fully understand the specs on the M1 and it's power supply. I most likely need additional 12VDC supply capability and in fact have an existing Altronix supplemental supply in my existing system.
I'm a detailed person and need additional details.
Thanks.
Thanks.
