Photon
I finally have an M1 set up on my workbench, and I've enjoyed trying the various features. I connected a PSC05 and it lets me control my various dimmer switches, lamps and appliance modules both through rules and directly from a KP2 keypad. I have a couple questions about using the X10 interface, and the printed instructions are, well, less than thorough. I defined the lamp modules and wall switch as Standard format, Dimmer type.
1. When controlling from the M1-KP2, the display says "# to change Dim=0-9." The # will turn a lamp module on or off. However, I cannot get any dim action. 0 turns it off, and any number 1-9 turns it full on. Is the dimmer function supposed to work from the KP2?
2. A rule ending with "THEN DIM Gar Outside Lt (39(C7)) BY 2 STEPS" turns on the garage light full bright and then dims it half way. If I dim by six steps, the light goes on and dims to full off. Since there are 32 steps available when building a rule, shouldn't there be more than six steps available to control a dimmer from full bright to full dim?
I've had JP2 in both one-way and two-way positions since the only two way device I have is the PSC05, and it behaves the same in both positions. The M1G hardware version is 0.13, and firmware ver 5.1.4.
Any ideas?
Thanks. . . . John
Any ideas?
Thanks. . . . John
