forgets
so my system with the elk M1XSP and the radioRa integrate seamlessly.. all the lights work perfect.. recently i picked up a in wall master controller with 10 buttons, hoping to use some of them to control states of other things through the m1 + relays.. i see elk lighting zones 177 - 248 can be used to accomplish this.. however they only allocate 5 buttons per each master controller.. when i was setting up master controllers to use this function, it seems like it's the right side (the side with all on / off) that is counted as what can be controlled with the elk..
here's a stock photo of what the keypad looks like, basically i'd like to use the buttons on the left to control other things with the elk, but the programming only seems to control / recognize the five on the right (and the all on / off) with the way the driver is programmed now.. is there any way to modify it to use another master controller's zones? i.e. have a 10 button controller use both zones for MC1 and MC2? or is an edit for the driver necessary?
thanks spanky and all the folks at elk!
