I'm going to make a homeseer plugin first and possibly others to follow, was hoping other might use the API to create plugins for actual products. The next release that will have an embedded HTML5 style Mixer for IOS\Android (or any browser). I was hoping between this app and the API it should be much easier for everybody to remotely control the amp via Tcp\IP.
As far as the quality, I think for the price you cant beat it. We can all debate about "Quality", but for me it's not a replacement for my living room amp or for home theater. It's more then acceptable level for music throughout the home, especially if your sources are "quality", meaning if you listening to a 64 or 128bit AAC stream, it's going to sound bad regardless. I recently played a CD via one of the sources and was shocked on how good it sounded
As far as power, it's more then enough inside I used the Yamaha NS Series In ceiling throughout and it sounds good, Now that it's finally "Warm" in NY, I'm going to work on the outside which may need a little extra juice or multiple channels or a bridge - will know soon.
Mike
