Napco FT2200 EOL Relay & Resistor
gcimmino
I'm looking for some EOLRs and came across the Napco FT2200. However, I'm not finding detailed specs easily.
It looks like it is both an EOL relay and 2.2k resistor in a single module. That would be great for the Elk, but what I'm trying to find is the physical dimensions of this.
Anyone seen one or know the size?
It is about 1.75 in length. About 5/8 inches in diameter. The lead length is just over 6". The black and red leads are power for the relay and the brown leads are the resistor leads.
Off of the top of my head I do not remember the current draw but its not bad.
Excellent, thanks. I wasn't thinking about EOLRs when I spec'd the pre-wire and the electrician chose to simply use a hole saw to cut into the plaster ceiling vs. installing a box. The 5/8" diameter looks just perfect for this application vs. the rectangular System Sensor EOLRs, not to mention the included 2.2k resistor.
