Need two delays from a single push button - one on for 45 seconds, one off for 1 hour. Right now I am using a microprocessor driving 24vac relays and then fan control centers to switch the 115V. But I would like to use something off the shelf for a cleaner install.
Looked at RIB and found one that looks like it will work but will require three relays - two RIBTD2401B and another to invert the input. The RIBTD2401B is nearly $100 so this would be over $200 total. There has to be something else that can do this.
It looks like all the RIBs delay the turn on, timing from the initial trigger signal and only hold the output on as long as the input is present - the opposite of what I want.
Am I back to an Aruduino or similar? For $200 I can get a really nice box to make it look good.
