I have a fairly simple z-wave setup:
Z-Stick primary controller (Node 1)
VRC0P (Node 2)
VRP03 (Node 3)
2 Schlage locks (Nodes 4 & 5)
Node 1 sees only Node 2, Node 2 sees 3 (and sometimes 4) and 3 sees 4 & 5. 4 & 5 also see each other.
I can run "update network" and I can reliably get from 1 to 4 & 5.
However, I'm having a problem with getting VRC0P to talk to Node 5 for some reason. The nodes information (and I assume the routing table) gets replicated. At least, I can run "FI" command and it shows nodes 3, 4 and 5. But when I try getting something like a battery status, node 4 works most of the time but node 5 always returns with X001.
I've tried playing with RO command but doesn't seem to make any difference. Perhaps I'm not using it correctly but I can't find any reliable documentation for it.
I'd appreciate any ideas. Not sure what to do at this point.
VRC0P (Node 2)
VRP03 (Node 3)
