Ok, I have ran into a problem where I have a GE z-wave dimmer switch next to a ceiling fan switch in the same box. The problem is when the lights are on and I turn the fan on/off the lights turn off. I was able to isolate the problem as being noise related by installing and X-10 XPF filter on the fan switch. This has solved the problem however the XPF filter is HUGE and won't fit in the box. Anyone know of a smaller filter that might work?
To get a visual, check out the thread on the issue over at the HS forums. http://board.homeseer.com/showpost.php?p=957086&postcount=25
