Need some advice...UPB Lights pulsing
I have all SA switches.
I have mostly CR6 bulbs in can lights.
I haven't seen any pulsing with the 6" versions.
I do have pulsing with the 4" but there are only two lights on that circuit, the 4" electronics may be a bit different from the 6".
The only other pulsing I have is with my driveway carriage lamps which have some "utilitech" (Chinese) candelabra type LEDs.
I chock the driveway pulsing up to cheap bulbs.
SA are also Gen 1 with some Gen 2 firmware upgrades.
They are more sensitive to th UPB signals because they aren't snubbed for noise suppression.
I wonder if that difference in electronics also makes them less prone to pulsing.
I installed the SA switch on set of 4-4" recessed LEDs, and there wasn't any pulsing.  I have reached out to HAI for a resolution.  As of right now, HAI has no answers.
Well. Good info. I won't install my dimmers till I see what happens. I guess I shouldn't install any, so I dont have different switch feel. We will see
HAI tech support has ordered an exact light that I have installed to see if they can find a fix.  Not sure on the time frame.  From what it sounds like, it's not something they can fix.  The switches are "not" field upgradable when it comes to firmware.
