johnlaroux
I came across this new device in development by some guys at MIT. http://www.kickstarter.com/projects/supermechanical/twine-listen-to-your-world-talk-to-the-internet
I saw this on dvice today. Did you get yours yet?I don't know. I will have to wait till the one I ordered shows up so I can see what all it does.
http://dvice.com/arc...ne-the-tiny.php
Dimension: 3.2cm x 2.4cm x 2.8cm (approx)
Infrared sensor with control circuit board
The sensitivity and holding time can be adjusted
Working Voltage Range: DC 4.5V- 20V
Current drain:<60uA
Voltage Output: High/Low level signal:3.3V TTL output
Detection distance: 3--7M(can be adjusted)
Detection range: <140°
Delay time: 5-200S(can be adjusted, default 5s +-3%)
Blockade time: 2.5 S (default)
Trigger: L: Non-repeatable trigger H: Repeat Trigger (default)
Work temperature:-20-+80°C
Trigger Method: L unrepeatable trigger / H repeatable trigger
