Occupancy Sensor Technologies
Passive Infrared (PIR) Occupancy Sensors
Passive infrared sensors monitor the patterns of back-ground heat energy in the space. When the sensor detects a significant change in the background heat energy it responds by automatically turning the lights on, or by allowing the lights to be turned on manually. When the background heat energy returns to a stable condition, the sensor turns the lights off. Passive infrared sensors must have a direct “line of sight” to occupants in order to detect human presence. In order to minimize false sensing, the sensors are designed to respond to the heat energy wavelengths that are emitted by humans.
Active Ultrasonic Occupancy Sensors
These sensors broadcast sound waves at frequencies much higher than the human ear can detect. The sound waves bounce off of walls, objects, and people. When the frequency of the sound waves returning to the sensor changes (the Doppler effect), motion is detected and the sensor goes into the occupied mode. When the sound wave frequencies stabilize, the sensor turns the lights off. Unlike passive infrared sensors, ultrasonic sensors can “see” around objects and surfaces as long as there are hard surfaces in the space.
Dual-Technology Passive Infrared and Active Ultrasonic Occupancy Sensors
Utilizing both passive infrared and active ultrasonic technologies, these sensors are designed for use in large areas, in spaces that are difficult to cover, and for areas where maximum reliability is important for safety or productivity reasons.
Dual-Technology Passive Infrared and Microphonic Occupancy Sensors
These differ from the sensors described above in that no sound waves are transmitted by the sensor. The passive infrared technology senses initial movement and continues to monitor the infrared activity. In addition, a microphone monitors sound waves and keeps the lighting on until sound activity stabilize
Occupancy Sensors With Daylight Override
Many manufacturers now offer occupancy sensors with built-in daylight sensors. The daylight sensing can be adjusted to keep lights off when there is sufficient day-light, even when the space is fully occupied. These sensors are a great choice for private offices that receive significant amounts of natural light.
