I have a 5 gang box with 3 "slave" switches from a 3-way, and 2 regular switches. The loads for the 3-ways all come into this box, and are fed from 3 other boxes. Running between the master and slave switches I have a wire with red, black, and neutral. I'm using HAI HLC switches, where the "Auxillary/slave" switch doesn't actually control any load, and just communicates with the "master" to do anything.
I've connected the black wire between the loads for the 3-ways in the 5-gang and the black wire in the "traveller" bundle, so that my master switch effectively controls the load independent of the aux switch. My problem is that in this configuration, my slave switches use all the wires from the circuit (ground, neutral, traveller) and I don't have a common from that circuit, since I'm using the black wire to actually control the load.
I can tap into a common wire from the 2 "normal" switches in the box, but wanted to check if that's kosher before doing so since they're all on different circuits.
Thanks!
Thanks!
