For years I've had a rule that calls my mobile phone when my driveway sensor is tripped and the system is set to away mode and it work fairly well. Over that last 6+ months when it calls it will not play the announcement and will not respond to key presses. If I dial in independently, it will respond to the yes and voice prompts will work. To make matters worse, it then keep calling every few minutes for about 4 times. I've tried adding pauses and beep, but it still will not work consistently.
I would like to switch to the email notifier, but I've heard it's buggy. I'm currently on 3.11 - I can only upgrade with a ROM replacement. Any help would be appriciated.
