WayneW
1) How noisy are the relays in the RC-2000? I realize this is pretty subjective, but some thermostats I have seen have pretty loud clicks and some are nearly silent. Obviously old mercury switch analog stats were dead silent, and I assume the communicating states that have the relays at the air handler.
2) How does the dehumidification control work? Does it just run the unit longer (extra cold) to get the humidity down) or does it signal the variable speed blower to run at a lower speed to get more dehumidification without excessive cooling.
3) When running in heat mode and the heat pump output is insufficient to keep up the desired temperature and the heat strips kick in, does the display indicate that the heat strips are on? does the heat pump continue to run even if it is too cold out?
