Has anyone used one of these cameras? In the specs it says up to 30 ips but is that at full resolution? Any issue with using it with an AverMedia card?
Ya can't the regular WV-CW484 is cheaper, well a bit, but PoE would be nice since I already have a PoE switch. An AverMedia card doesn't care if you have both IP and analogue right? Could I get better FPS just using the analogue and AverMedia card?
I have installed about 200 of the NW484 in the last 1.5 years. They work very well. They give you full frame rate at the specified reslution (640x480 VGA). Less if you are using the dual stream ( Max 5 ips VGA using MJPEG)
The picture is much better on a NW484 (IP) vs. a standard CW484. I have CW484's at my house. The NW484 image is better quality.
I have not used the avermedia card.
If you are interested, I have A WJ-ND300A for sale with about 9000 to 10000 hours on it. I'll make you a good deal...
