Phase Coupler, URD Signal Test
slowmo
I've installed a Phase Coupler at the panel and noticed a Signal@PIM drop in all 12 devices from the mid 80's to the high 50's. Also the same observation made at the Signal@Device. Is this a problem?
Also, I have a couple of SAI - URD30W firmware v1.02 which are very low Signal@PIM and @Device compare to firmware v1.10. Some times v1.02 sporadically looses connectivity. Is the firmware a problem or is it my imagination?
Scott
Scott
What is a "very low" signal? UPB works well with any signal above 9 on the 1-100 scale.
You can always contact SA tech support on their products and UPB in general.
Customer Support 8am - 5pm PST, Monday - Friday
800-630-9234 x138
[email protected]
Dave
Dave,
Nice to hear from you. "Very low" meaning in the low 30's. It sounds like the sporadic connectivity I experienced may have been caused by something else. I did speak with SA and they are replacing the v1.02. In the mean time I purchased two more URD30W thinking I was getting the latest version 1.10 but ended up with again v1.02. I’m reluctant to try v1.02 but from your description they should work fine.
Scott
Scott
What brand of phase coupler? I tried an SA (inverting) and a HAI. The SA made things worse, the HAI much better.
