I'm about to deploy a bunch of POE surveillance cameras around the house exterior.
What do folks think about running CAT5 cables under vinyl siding and/or along the siding edge channels? I DID once run the grounding conductor for an OTA TV antenna along one of the siding 'J' channels, so I guess I've already started the practice.. But not yet for signal cables. Running below/beside the siding would make a few of the camera placements a LOT easier to cable.
I'm thinking about using direct burial CAT cable for these runs. Or maybe plenum grade cable. I'm hoping that nowhere the cable is exposed to direct sunlight (i.e. UV), but I can't depend on it.
Should I install surge-protection for these type of runs?
Thoughts? Any other camera cabling tricks-of-the-trade?
