Gentlemen,
I'm in need of advice on whether my existing pre-wire will work with the ELK-M1.
Question 1:
While in a rush to complete the security wiring back in 2000, I screwed up and ran standard 22/4 (not CAT5E) to 4 locations for security keypads. All locations are wired as home runs.
After reviewing the M1 documentation, it looks like I can get around the Keypad daisy chain/buss termination requirements by using the M1DBH data bus hub (expensive mistake).
Now I'm worried about interference using the 22/4 for the RS-485 communication. What are my chances here? I was at least careful to separate the 22/4 from the house wiring, but I would like to the the M1KPas in 2 locations (triple gang boxes with standard switches adjacent). I'm in the process of finishing the basement and will be loosing what little access I have. Is this a reasonable risk, or should I get out the drywall saw?
Question 2:
While all of my entry points are currently wired (open/close) I would like to add Lock confirmation.
Entry points include:
I ordered one of the following Inductive sensors to play with: Inductive Sensor
I'm curious whether anyone has previously tackled the problem of deadbolt/latch monitoring. In particular, my workshop is located beneath the garage (10" thick reinforced concrete walls and pre-stressed concrete ceiling. Is there an approach for interfacing the above sensor to a ELK compatible RF transmitter?
Thanks in advance,
IM
Question 1:
Question 2:
- 4 steel doors (deadbolt monitoring)
- 1 steel double door (center latching deadbolt - RF?)
- 2 - Pella Sliders (Latch monitor)
- 1 - Pella Double Slider (center latching - monitor foot latches?)
Thanks in advance,
IM
