Problem with HS script for Dallas DS9097U adapter
Jimboat
Can anyone help?
I am having trouble with the script that gets my temperature readings from my 1-wire network. everything has run flawlessly for over 2 years, until my DS9097U failed and i replaced it. The new adapter reads the temps fine (using the Dallas i-Button Viewer), but the HS script now fails! I am running vbs with HS 1.7 inw WinXP (not in .net).
I am using the using Dallas Semiconductor DS9097U COM port adapter and DS18S20 Temperature Sensors. I have loaded 1-Wire drivers version 3.2 and SDK version 4 (tm320b_32.exe).
The only difference that i can see is that the old DS9097U-S09 and new ones provided are DS9097U-009. I don't know what the difference is, or if there even is a difference.
The error that i am getting is:
8/11/2008 6:47:16 PM~!~Error~!~Script error in file: get_temps.txt: 7:Out of memory: 'CreateObject' in line 63
line 63 is...
Set access = CreateObject("owapi.OneWireAccessProvider")
in code below...
' get_temps.txt
' define public variables
Public currentTemp
Public owAddress
sub main()
' main subroutine
Call GetTemps()
end sub
sub GetTemps()
' Get temperatures and assign to virtual devices
Dim access
Dim adapter
Dim i
Dim owd_enum
Dim owd
Dim deviceState
Dim deviceName
Dim CRLF
dim set_date
' make control line feed
CRLF = Chr(13) & Chr(10)
' get the 1-Wire access provider
' get the default adapter
'Set adapter = access.getDefaultAdapter()
Set adapter = access.getAdapter("{DS9097U}", "COM9")
hs.WriteLog "Debug", "Adapter: " & adapter.getAdapterName & " Port: " & adapter.getPortName
adapter.beginExclusive(true)
' clear any previous search restrictions
adapter.setSearchAllDevices()
adapter.targetAllFamilies()
adapter.setSpeed(adapter.SPEED_REGULAR)
Set owc = CreateObject("OWAPI.OneWireContainer10")
i = 1
While adapter.findNextDevice = True
owAddress = adapter.getAddressAsString
owc.setupContainer adapter, owAddress
deviceName = owc.getName()
'get temperature
Set deviceState = owc.readDevice()
owc.doTemperatureConvert deviceState
currentTemp = owc.convertToFahrenheit(owc.getTemperature(deviceState))
hs.WriteLog "Debug", "Device Found: Address(" & i & ") = " & owAddress & " Name = " & deviceName & " Temp = " & currentTemp & CRLF
hs.SetDeviceString "t" & i, currentTemp & "° F"
'set the time & date on the temp devices t1, t2, t3, etc.
set_date = now
hs.SetDeviceLastChange "t" & i, set_date
Call LogTemp()
i = i + 1
Wend
' end exclusive use of adapter
adapter.endExclusive()
' free port used by adapter
adapter.freePort()
end sub '*** end GetTemps()
sub LogTemp()
' Log temperatures to a database
'* Declare and set objects/variables
' name of Access database file
Const strDatabaseName = "temperatures.mdb"
Dim objConn
Dim strConnectionString, strDatabase, strSQL
strDatabase = hs.GetAppPath & "/" & strDatabaseName
strConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & strDatabase
' Open database connection
Set objConn = CreateObject("ADODB.Connection")
objConn.Open(strConnectionString)
' Insert row
strSQL = "INSERT INTO tblTempLog (owAddress, Temp, ReadingDTS) VALUES ('" & owAddress & "', " & currentTemp & ", '" & Now &"')"
hs.WriteLog "Debug", strSQL
objConn.Execute strSQL
' Close database
objConn.Close
Set objConn = Nothing
end sub '*** end LogTemp()
It looks like the addressing scheme is different for that adapter:
http://www.ibuttonlink.com/ds9097u-009.aspx
The DS9097U-009 is a sophisticated RS232 to 1-Wire adapter, which performs RS232 level conversion and actively generates the 1-Wire communication signals. Functions the same as a DS9097U-S09, with the addition of a 64-bit address.
A low cost solution for very short, lightly loaded networks.
So I don't think it's just a direct replacement, without making changes to the driver.
Hmmmm - thanks Dan, for the idea. The writeup says "Functions the same as a DS9097U-S09, with the addition of a 64-bit address", but maybe the "addition" changes enough.
Any idea where i can get the driver that applies to the ds9097u-009?.
