If it is simply for CCTV of something it probably isn't an issue.
I find it helps to think of the cost in relation to the work involved in pulling it all out to upgrade in a few years
OK guys, I have another question to ask in regards to my RG6 Quad Shield BC (Bare Copper) and RG6 Quad Shield CCS (Copper Clad Steel) dilemma.
I'm looking at my previous bought and run RG6 Quad Shield and I can't determine if it's BC or CCS.
Can someone tell me if this is good to use for future satellite? This is what is printed directly on my cable:
VERTICAL E312655 RG6U QUAD 18AWG COAXIAL CABLE 3.0GHZ (UL) C(UL) CM/X/G FT4/CATV(UL)/CL2(UL)/AWM STYLE 1354 (VID:S2)
I don't know much about RG6 Quad Shield. I thought I did, until I went to buy more and now the guy I bought from sells BC or CCS quad shield cable. Is there an easy way to tell if my wire is bare copper? ie.....look at the tip of the bare wire and would the outside be a different color than the inside?
Basically I need to know if what I have listed above on the cable is good for satellite HD. I found this site that says it is, but I'm not even sure if it's the same stuff that I already have:
http://www.directron.com/ccr61kqsbxbk.html
Yes, I've mentioned in other threads to use cable swept to 3Ghz. As long as you are doing it use RG6 Solid Quad 3Ghz and you should be fine. Most DirecTv installers are contracted and may use different cables. I allowed them to install the dish but insisted on using my cable.
I have a hard time suggesting that the OP pull out his runs of copper clad steel. If this was a high end video production studio, then I would suggest it, but for piped in PBS going to the guest room? Well, that just seems a little over the top. I suspect the OP will be fine with what he has. However, he might want to consider a couple of conduits if the walls are still open. In my house, I have two key runs of flexible conduit--Carlon Resi gard, the plastic orange stuff--in the walls coming in from the cable's point of entry, going to the central wiring panel, and then going to the main TV viewing area in the house. This way, if the technology changes substantially, I can at least repull the cable coming in from outside and going to the main TV in the house. Just a thought.Personally, yep, I would redo the runs. :lol: You will probably thank yourself in the long run.
