Hi,
I have purchased a M1 and I'm deciding on the wireless controller, leaning towards Honeywell since they seem to have so many sensors.
However, I'm reluctant to use the recessed door sensors (e.x 5818MNL) as they require a 0.75" x 3.0" depth hole be drilled into the jamb. Typically this hole will be very close to the edge of the studs. I know in practical terms this will not really weaken my framing but I would rather accomplish this with a smaller hole.
I was thinking to use the 5800Micra as it requires only 0.75" x 0.5" depth. I would have to drill an additional 5" deep hole to accommodate the antenna and could use a straw to feed it. The antenna exits the transmitter at the edge so the antenna hole should be offset. The magnet would also have to be recessed and unfortunately it's not round but that's OK as I could place it on the top of the door and/or putty around the magnet.
Does this sound reasonable or has anyone done this?
