I see where you are going with that. I also went with the zoned system as I was trying to put equipment in the basement, and share it across the house. While ideally I would be able to serially control everything, I don't see myself there for quite some time (TV's don't have that for example, not even the 61" I got, although I need to double check that).smee said:Addressing the connection to the Xantech system issue...
I distribute IR using a wired Xantech system (wired for 3 zones, but the max I've used is 2 and 1 is disabled right now (intentionally)). I have HomeSeer and a USB-UIRT connected to the system.
Initially, I was planning on using an optoisolator system to connect the USB-UIRT to the Xantech system. I ended up doing something different - partly because I had the parts on hand and partly because I wanted to maintain easy manual control (using hand held remotes).
I use standard Xantech IR receivers (291-10 Hidden Links) at various locations all on zone 1 (I had one on zone 2 also, but I took it to use on zone 1. That's why zone 2 is disabled). One of these is near the computer. I use two standard "mouse" emitters plugged into the USB-UIRT and attached to the front of the 291-10s. These essentially become optoisolators. This setup is more expensive, but it allows me to use a standard remote in the same room (without going through the computer) - I don't always need everything automated .
That approach would be hard as I use an eye for each zone in different rooms. I've never thought about it, but can I hook up multiple eyes to a zone? It would add $50 or so per zone (an eye in the real room, and one in the basement for each zone). I'll have to see what options are available. FrankMC posted one, but it looked more like an example to build your own (and I did not look around enough to find the details or not). Curious what that would cost as it may be cleaner (not sure if there is any 'loss' when running the output through another eye).
The card would also work well as it seems I could plug in two if I needed. This would complement the Xantech setup, should I ever outgrow it since there is a six zone expander which would bring the total to 9 zones. Two cards would give me eight zones which I suspect will be fine. It will take me awhile to finish equiping some of the other rooms anyway.
And to Dean's point, it seems like it would be cheaper. I'll take another look at what GC is providing as they had some other functions other than IR, but I don't think I needed any of that which would make the comparison cleaner. Also would be nice to avoid yet another box.
