felixrosbergen
Hi All,
I just found out the 51" Sony Rear project DLP (HD) i have had for 4 years actually has 'remote in/out' connections which appear to be headphone jacks (3.5mm i guess).
Does this mean i can send it IR over hardwire or does this still use some sort of proprietary control protocol??
If i can send the TV IR com,amd directly via wire this open up some good possiblities. I assume the remote out woudl then forward whatever IR the TV receiver to what is connected to that port.
Is there stanard wiring for headphon jacks relate to IR. The few IR blasters i've seen have had what appears to be 2 connections (tip and 1 sleeve) but i recall reading somewhere that hardwired IR is 3 wires...is that simply become you have a common and 1 signal wire to send and anther one to receive?
When connecting additional zones to the USB-UIRT are these blasters only? I recal reading that USB-UIRT have 3 zones, but there is only 1 jack. Does this mean a need a plug with 2 'sleeves' and each sleeve is a zone?
