bbruck
I've been looking for a way to retrofit my house for a zoned heating system. Due to the fact that my basement is finished and the ductwork was not designed for multiple zones, my heating contractor says it would cost $5k to install zones. I've been looking for an inexpensive motorized vent system that I could integrate into my home automation system, and I'm wondering if you think the following would be possible:
Springfield precision instruments makes a product called Vent Miser, which is basically a motorized register with a removable timer, powered by AAA batteries. It sells for $29 on Amazon (http://www.amazon.com/Vent-Miser-91664-Programmable-Saving-10-Inches/dp/B000MWBPKA), significantly cheaper than other motorized vents I've found.
I'm thinking perpahs I could run an appropriately rated wire from each damper through the plenum to a central controller that would integrate to my HA system. Then I could remove the timer from the vent miser and either (a) send the on/off signal through the wire, bypassing the timer feature but still powering the servo from the timer batteries; or
) send the power through the wire, completely bypassing the timer.
I know either of these would mean modifying the device and in the (a) scenario, taking it apart to modify it - which naturally voids the warranty - but I'm wondering if you think this might be feasible?
