miamicanes
I'm finally rewiring the living room. I'm going to be removing the lower 3 inches of drywall behind the old baseboards, installing Wiretracks at the top of the cavity, and running power cables at the bottom, before mounting the new 5-1/2" baseboard to the wiretracks. It's the closest I can get to "in-wall", because the drywall is mounted to furring strips nailed into concrete, and the area that would otherwise be ~3/4" of empty space is filled with foam insulation.
I know running power and data lines in parallel close proximity is a Bad Thing... but would the use of grounded, aluminum-armored power flex-cable instead of unshielded Romex make any real difference? Or is there anything I can do at installation time (loop the cat5 bundle through big ferrite rings every few feet?) to mitigate the problem?
