There is no way to generate buttons 5 and 6 according to GE. The only way to do this is to set option 1 and option 2 in the ELK for the keyfob which changes 7 and 8 to 5 and 6. So in the end, you still only have 6 possible events that you can send from the remote.
However, Consider this scenario:
Code:
WHENEVER KEYFOB BUTTON 4 IS PRESSED
THEN TURN OUTPUT 201 ON FOR 5 SECONDS (RESET TIMER IF ALREADY RUNNING)
THEN INCREMENT COUNTER 10 BY 1
WHENEVER OUTPUT 201 TURNS OFF
AND COUNTER 10 IS 1
THEN TURN ON GARAGE LIGHTS
THEN SET COUNTER 10 TO ZERO
AND COUNTER 10 IS 2
THEN TURN ON OUTSIDE LIGHTS
AND COUNTER 10 IS 3
THEN ACTIVATE TASK 04
AND COUNTER 10 IS 4
THEN ACTIVATE TASK 7
This would give you the ability to perform different actions based on the number of button presses, effectively giving your remote the ability to do more than just 6 things. Since there are 6 possible button presses, and you set up multiple keypresses for up to 4 keypresses for each button, you'd have 24 possible things that the remote could do. 5 would give you 30. Technically, there's no limit other than remembering how many presses of each key does what, and the maximum number of rules.
Or.... You could designate the Aux button (4) as an enter button, and buttons 1-3 would be for entering digits. You would have a 3 digit code for each function that you wanted to control, for example:
141 = Garage open
231 = Turn on garage lights
341 = execute task 07
Then, your rules would look like this:
Code:
WHENEVER BUTTON 1 IS PRESSED
THEN INCREMENT COUNTER 1 BY 100
WHENEVER BUTTON 2 IS PRESSED
WHENEVER BUTTON 3 IS PRESSED
WHENEVER BUTTON 4 (AUX/ENTER) IS PRESSED
AND COUNTER 1 IS 141
THEN OPEN GARAGE
THEN RESET COUNTER 1 TO ZERO
AND COUNTER 1 IS 231
AND COUNTER 1 IS 341
THEN EXECUTE TASK07
Assuming you use only the digits 0-5 in your code, this gives you 120 possible functions. Also, I don't feel comfortable making my remote able to disarm the system. But designating a code for disarming this way would make me not worry so much about losing my remote. If you have multiple remotes, you can use the "last user was" to make it do this only on your remote. I know my wife would probably be annoyed if I did it to hers.
