nightwalker
I've just had a HAI UPB 8 button keypad go south, worse was I watched it go and could do nothing.
My nephew was visiting this weekend and seemed to have built up some static electricity in his body from draging his feet and then touched one of my keypads to turn on a light. I saw the slight spark just from his finger to my keypad and then the keypad put on quite the light show, flashing one led at a time then to all at once and finally settled down. Now it only works sometimes locally, it does show status of the devices it's tied to correctly. Operating it locally it sometimes works, sometimes not.
My question is, is there someway to prevent this?
Those things get pretty expensive to have to change to often. I opened the switchbox and while it's a grounded box I the keypad itself is not grounded and has no provisions to ground it, it's a completely plastic/fibre body with only the two leads for hook up.
I don't know if grounding it would help anyway but there has to be a way to prevent it, without give all persons here a grounding strap.
Anyone have any thoughts?
