georgemeaders
We are remodeling our basement, and have it down to the studs, so with the basement open, along with the crawlspace, we have relatively easy access to get up into the main floor walls and decided to set up a central wiring panel in the basement laundry room. We are planning on 2 data (cat5e) lines, 1 voice (cat5e), and two cable (r6) lines for each termination point. The one thing I am having a hard time figuring out, is how to run a line from the network interface box outside the house to what will be my central wiring panel inside. Do I run one cat5e cable with a just one single wire pair (blue/white blue for instance) hooked up for my data inside, and then run another separate cat5e cable with a different wire pair hooked up for the voice line distribution? I'm sure more questions will come, but this is one I can't seem to find anywhere, probably because it's something obvious to most people....
