CAI_Support
Thanks for your inputs Tom.
Tschmidt said:I'll weigh in - for my projects using a 5V USB connecter has no value.
Tschmidt said:I like being able to use a higher input voltage - I use 9V, it lets me do my own down regulator if I need 5V and 9v works fine for most 12v devices, fans and relays.
If you are going to respin the board my personal preference is to use a switch mode down converter (like WC32) so input voltage can be 12V without wasting energy or creating too much heat. If direct 5V operation is desirable for marketing purposes why not use a PTC or fuse and a shunt diode. That will protect the board from reverse power.
Certainly the wider the better, but if you can implement a SMPS that goes down to 4.5v that is great because then it solves the problem of running directly from 5V. The upper limit is more fluid. Does anyone need more then 24ish volts for a directly powered unit?CAI_Support said:It would be nice to be able to take 4.5V to 40V range.
Tschmidt said:Certainly the wider the better, but if you can implement a SMPS that goes down to 4.5v that is great because then it solves the problem of running directly from 5V. The upper limit is more fluid. Does anyone need more then 24ish volts for a directly powered unit?
While we are on the topic of redesgining the power supply, this probably allso apples to the WC32 but I have not dug into that spec. Are you looking into PoE? If so the switcher will need to support higher DC voltage. I would think that would be a useful feature when the WC is used as a data logger without access to mains voltage.
/tom
LarrylLix said:How do users tell what devices CAI WC can interface with?
Geeez I hate this forum with no cut'n paste....
This lead me to believe there is a big hole in your statements about special code for each device.
I bought the wrong product.
I have no interest in I2c devices
A commercially produced weather station at $6-700 is starting to look cheaper and a lot more reliable.
