CAI_Support
Hi Todster,
We are trying to digest what you and Ross suggested. Ross suggested instead of VARx, an IOID by the name VAR with parameter being used. When the parameter changes, the VAR will reference to the value of that VARx. From my understanding, you suggestion is to have the reference value change the ratio of the VARx being applied. Are the ratio is based on second, minute, or other time base? What is the start point, I assume the older value? Assume AIP1 and AIP2 are changing over the time.
We will look into the possibility of each suggestion. Currently we can not commit if we can implement or not. We want to understand clearly exactly each instruction will have what behavior.
Thanks for the suggestions.
