Also see if you are running the latest firmware. Not saying that there was a bug fixed relating to this, but it is always good practice when you are experiencing a problem to check your firmware.
When I do it for 2 seconds it works. This is the same problem then that I have with my lighting with the ELK. When I Try to do a lighting from the elk it will show on for a few second and then turn off. so my guess is that after it turns on the satellite heater it thinks that it went off a few seconds later even thoe the sateittlie heat is still on.
This is a major problem with the elk system. does any one know how to fix this ?
In Global setting if I turn off the Report to serial port 0. the lighting. The it will work as far as turning on a light and off after any set amount of time. That a step in the right direction. but buy turnning that off I now cant get any report of what is on or off when I am away from any keypad. So now From the internet I have no way of monitoring the lighting system.
So I guess the Problem could be from eather the M1G, Or the Network Add on. I guess
I take it back nope it still doesnt work!!! This is really get frustration. about to give up and go with another controler! I would hate to have to change everything out but this just does not seem to work no matter what I do.
