Hello,
I have 8 temp sensors purchased from Mouser pn DS18B20+ which I selected because the specs indicated they were more accurate than some of the others. The wiring for the most part is star configuration which I know is not the best from what I have read. The approximate distances are 2ft, 4ft, 5ft, 6ft 10ft, 15ft, 20ft and 40ft and I used cat5 cable for all runs.
They all work fine most of the time. However every once in a while, maybe a couple of times a week one randomly will show 3920 for a few seconds then return to normal. Every one of them at one time or another has done this. Is this a known problem, have other experienced it?
I have installed a 4.7k ohm pull resistor up from Vdd to DQ at the sensor at the longest run. I also added one at the second longest run as well.
The board is rev 2.0.2 with firmware v03.01.06 and I modified the board per CAI to supply 5v to the temp sensors instead of the 3.2v.
Is it ok to add a pull up at every sensor? If ok would that be a possible solution or am I dealing with another issue?
Tim
Tim
