A few questions about the Elk M1G databus.
1) The instructions for the databus hub say to use the 568A wiring standard. However, I re-utilized some ethernet cables that already had tips on them with 568B standard. Does it matter as long as everything is attached right at the ends?
2) How many databus errors per day are acceptable or normal? I was getting about 1-2 per day, but since I added an external input expander and relay board, I'm getting more like 75-100 per day.
3) Assuming that the above is too many errors, what is the best way to go about testing the wiring? In my case, the total cable length is pretty short, probably not even 200 ft, even including there and back again. And all devices are visible. I'm confident that the ends are terminated properly But I'm concerned about long term reliability with so many errors being reported.
4) Some keypads are reporting more databus errors than other keypads... is this normal?
Thanks!
Thanks!
