thermometer ideas
Did you see my post with the link? You only run the wire in the freezer.
I saw it. It was a little confusing because you said "simply place the sensor inside the unit" instead of the probe/wire.
That suggests drilling a hole thru the freezer. With my luck I would hit a wire or a refrigerant tube.
Ira
If you have an ice maker then there's already a hole. In my freeze I just ran the wire from the back across the rubber and into the compatment. The wire is small enough to conform to the gasket.
The sensor on these units is the small bulb at the end of the wire.
Unfortunately for me, those sensors are not compatible with the OreSci WMR100 weather station, and there's not a comparable sensor for the WMR100.
Ira
