I have a number of rules that have multiple THEN lighting instructions. When the rule is fired typically 4 out of 5 lights are switched on sometimes only 3. The same thing happens when I switch them off however if I stagger the of times by a few seconds they will switch of reliably. What need to be able to do is put a time delay in between the THEN instructions, is this possible??
It appears that flooding the C-BUS data BUS with the salvo of on commands sees some missed and therefore staggering the on commands should see a reliable outcome. Is it possible within rules to do this??
Regards,
Fleetz
Regards,
Fleetz
