I have an existing M1 install, running 5.1.20. It had the following serial devices:
0: XEP
1: XZW (1.0.16)
2: XSP (1.0.46) hooked to RCS thermostat (in bldg 2)
3: XSP (10.0.2) hooked to Uplink
I wanted to replace a non-integrated stat with an OmniStat 2000 in bldg 1. In the XSP docs, it seems as though an OmniStat with address 1 needs to connect to an XSP addressed as Serial #1. So I renumbered the XZW as serial 4 and put a new XSP with 70.0.2 firmware as serial #1. Result is:
0: XEP
1: XSP (70.0.2) hooked to Omnistat 2000 (in bldg 1)
4: XZW (1.0.16)
The RCS, which is "TStat 1" in ELK RP continues to work just fine.
The new stat, which is "TStat 2" is flaky. I've seen the temps change under M1 control twice, but with many failures to change in between. I've been able to send text strings to the stat's display with the "Send Text" rule.
I'm looking via eKeypad on an iPad and I don't see any current temp values returned for the new stat.
70.0.2 was released on 27 Oct 2008 and 5.1.20 on 3 Jun 2009, so I'm presuming there's no issues with the M1 firmware level supporting the Ominstat 2000.
I've double checked the jumpers on both the XSP and the Ominstat as well as the Omnistat setup.
Any ideas on where to look?
0: XEP
1: XZW (1.0.16)
0: XEP
4: XZW (1.0.16)
