Trouble communicating with RC-2000 thermostat
beelzerob,
Here are the relay bit assignments, but things can get a little screwy because of the variety of HVAC systems out there. You should be able to figure things out from the information I provided above and these bit assignments:
Bit 0: Heat/Cool
Bit 1: Aux Heat
Bit 2: Stage 1
Bit 3: Fan
Bit 4: Stage 2
Bit 5: Humidifier
Bit 6: Dehumidifier
The humidity is reported in percentage, 0-100% RH.
Thanks Brian! That's {Bit 3}tastic! :P
Thank you so much for all the help, you have definitely made me a believer in HAI hardware.
