[Tutorials] How to build an X-10 broadcast car monitor
electron
Administrator
Staff member
Many home automation enthusiasts like to monitor if their car is home or "on the road" with their automation systems. One way this is accomplished is by using an X-10 motion sensor mounted under the steering column. When motion is detected (from the driver) a unique signal is sent that represents the presence of the vehicle. This method has many short comings though.
One solution would be to have the vehicle "broadcast" a unique X-10 signal when it is started and then broadcast another signal (at longer intervals) when the car is turned off.
This How-To will describe how to make such a unit using a "hacked" palm pad remote.
For starters you should be familiar with the How-To describing How To Hack A Palm Pad Remote, as we will be using this methodology here.
Click here to view the article
