acdcelectric
Has anyone had any problems with UPB signals from one house activating devices in another?
I have 3 houses on a cul-de-sac with UPB installed. 2 of them have ID numbers only 1 digit apart while the 3rd is very different. The two that are only one ddgit apart can turn lights on and off from across the street. NOT GOOD!
According to the UPstart manual, there are supposed to be 250 discrete ID numbers available to prevent this type of interference.
With a theoretical range of 2 miles for the UPB signals, I really need to be sure that there is no interference between customers. Can you imagin trying to troubleshoot signal problems with a 2 mile radius.
Is the Network Password part of the isolation requirement? The two that have the problem share the same password. Again, the manual says the password is only to give you permission to write to the devices.
Is anyone from SAI on this forum?
