wdeertz
I'm using OmniPro 2 with UPB lighting control. I have roll away hurricane shutters on my patio that I'd like to control via UPB. The existing switches are rocker switch with one direction for up and the other for down. I see no issue getting a UPB rocker switch but need a solution to shutoff the motor when the shutters are either fully down or up. If power is left on once fully closed or up it will burn up the motor after a period of time. I could use a timed approach for automation but this wouldn't work if the shutters got out of sync. I thought about wireless sensors at the top and bottom of the shutters to signal once they are fully extended but this isn't failsafe.
If there was a switch which shutoff when the amperage spiked (which I am assuming would happen when the shutters became fully extended) that would be ideal. Is anyone aware of hardware that will work for my situation?
