Hi,
I have installed two UPB switches so far. The first is a single HAI 600W dimmer, Works perfect from the first time I programmed it. The second is a single HAI 600W dimmer with two remotes, At first I could not get it to respond to upstart. I changed the breakers around in the sub-panel the circuit is powered from(from one phase to the other). After that the switch has been perfect. Both switches are being controlled by my Elk M1.
My question is, Do I need a phase coupler? I have 8 more switches arriving today and before I install them and start troubleshooting any problems, Should I order one?
My house is about 5000sqft, I have a main panel with a 100A sub-panel mounted next to it, a 100A sub-panel in the garage at the other end of the house, and a 100A sub-panel by my pool pumps about 300' from the main panel.
Thanks for any input,
Mike
Mike
