I'm curious if anyone here has tried using the Nexus S as a keyfob yet? I'd like to explore an option that would use an Elk M1G, but I'm open to other suggestions.
If there's nothing that will work with the Elk directly, all I need to make things work is some device to read the NFC code and output it as ascii or hex over a socket port via tcp/ip or via a COM port when my phone comes within an 1" of a pad. I have zero experience with NFC, so I'm hoping someone here does
