WebAmp as 5v power source?
bbrendon
Ross-
Can I use the webamp +5v regulated power source for 300ma? I need 5v @ 300ma for 1 second to activate some locks I have.
I don't have a handy 5v power source on my wall so I thought I might use this one.
bbrendon said:
Ross-
It will depend on the voltage you are feeding the board. If you are giving it (say) 15V DC, the regulator needs to drop 10V (15Vin - 5Vout = 10V drop).
Measure the current the WC board is taking now and add your 300mA. Eg, if its now taking 200mA then add 300mA = 500mA total.
Power dissipation = 0.5A * 10V = 5W. It should be ok for a few seconds. Just make sure you put a decent freewheeling diode across the coil, otherwise the inductive spike it produces when you turn it off could easily kill things!
