I had a bunch of X-10 in my house, so I replaced it all with Smarthome switchlinks (i think they are called).  Then I added some Insteon but use it with X-10 commands.
I am using the Smarthome PC/timer module. The quality of this is terrible. My second one just failed.
The robustness (if that's a word) of Smarthome's X-10 is not as good as the cheap X-10 was.
I have learned to live with compromise, but now I want something that will work completely- or at least as complete as a non-wired system can.
Because of the poor build quality I don't want to try to use Insteon. Also a critical component, IR to Insteon, doesn't exist- though I see that it is comming soon.
I have about 13 light switches, and about 5 plugin modules to replace.
I need a box that can store timers to turn lights on and off.
I need a way for my learning IR remote to send a command that can then trigger a scene or scenes to dim the lights for a movie, or set different moods.
I need a tabletop keypad that can be programmed or or send a comand that will turn all lights off, all lights on, or light that I choose as a group to go on, off or to a specific level.
I think There are UPB products that do all of these things.
What I don't to have to do is replace failing equipment every other year.
Looking at https://www.automatedoutlet.com/home.php?cat=169 There is a wide price range.
For quality I am looking for a few things: Reliability, feel, and dimmers that don't make the light ring.
What are your thoughts? do you have any specific recommendations?
thanks,
~Jay
thanks,
~Jay
