oldchachie
I'd like to add some automation to my garage and house. I see insteon has a pretty good setup for controlling lights and outlets, using their equipment which ultimately communicates without adding any other wiring, I'm not sure if their wireless, or if they send signals back through the 110v wiring. So either way, I'm looking at their switches which look like they are about $50 each, which seems a bit steep. I've got my walls opened up right now, and I'm wondering if theres a cheaper solution maybe a wired application or if insteon is the way to go.
For example, I would like to shut the lights off in my garage from my elk controller. I'm wondering if theres a type of switch that I could wire a 12 or 24 volt signal wire to as well as the 110v for the fixture which will turn the fixture on or off. Any help would be appreciated.
