Hi . I'm new to Home Automation and relatively new to CooonTech.
I have a new house under construction and the electrician has just come into the picture. Recently I purchased the M1 Gold system and plan to use it.
I want to be sure that all my switches and associated fixtures can be later retrofitted with UPB devices. From what I understand they have to be wired correctly or a UPB device will not work.
In reading some of the UPB literature , I read that UPB devices use the Neutral ( WHITE wire) .
The Electrician just looks at me funny when I say that.
HE says on a normal 2 way switch , he uses 12-2 wire with a White Neutral wire , a black hot wire , and a Bare ground wire. On a 3 way switch he uses a 12-3 wire which has all the above plus an additional red hot wire.
Could some of you knowledgeable tech Gurus please tell me what I need to know so I can communicate to him what he needs to know so UPB devices will work in the future ?
Thanks for your help !!
Snickster
Snickster
