royalj7 said:
The way you fish wires is a very individual process. Myself, I pull my wire from the headend to the sensor/jack locations so I don't have to move the cable bundle around. However, I know a good electrician buddy that does the opposite, and he gets along pretty well. So, if you have wire that is on a reel, not a box, I would get some scrap 1/2 to 3/4" conduit and thread it through the reels and set them on some tire jacks. They also have wire reel setups you can buy that do the same thing. Tape you wire together at the end when you are pulling it through and it should go ok.
Hope that helps,
--Jamie
I have only done a few houses, but I found pipe clamps work perfect for reels. If you don't have any, they cost around 5 bucks at harbor freight (plus the pipe). 1/2" ones work fine.
Depending on how many reels you want to support, make the length of the pipe long enough to hold the reels plus another foot or so. When you are ready to start, just tighten the clamp on a stud wall and slide the reels on and start pulling...
Brian
