You don't need them - they're an extra layer of protection if you *want* them.
They help protect against a short in the wires that you don't know about, or the theoretical case where someone would short out the sensor wires before the sensor so they could open a door/window unimpeded (highly unlikely in a residential scenario).
They're rarely used in residential, if any security systems.
.... [Edited]
If you don't have eol resistor mode on, the alarm will interpret a short as a closed window/door, since electrically they are identical.
Lou's absolutely correct... yet still they're almost never found in a residential install.Without eol resistors the alarm has no way of knowing about a purposeful or accidental short in the wire.
With eol resistor in place there are only two states that the alarm should see, 2200 ohms, and open circuit. If a screw gets put through the wire or a mischievous service person is in your house decides to short out a zone for future access to your home, the alarm will see a "short" condition and report fault. Also, if a short occurs, the alarm reports it immediately. So if you are hanging a picture and put a nail through the wire, you will know right away and be able to pinpoint the problem. If you didn't get that immediate message, you might not discover the problem for months or years and have no clue when/where the damage was done.
Where would you put the resistors? One by each window or if they are in series, you would need only one?
I agree, and I don't know why they aren't used in residential systems -- it is just not that big a deal to put them in. It does help if you know how to solder, but there are solderless connectors you can use, and with door and window sensors you'll have to use something regardless to connect the sensor leads to the cable.
I will point out something... I don't know how the Elk does it, but with an HAI system, a shorted security zone is treated as open, and it results in an alarm condition (rather than a trouble condition) if the alarm is armed in the proper mode for that zone.
Yeah, mine are similar to this:![]()
I'm pretty careful about who I let in my house - they're generally not people who would be tampering with my security system... plus I keep chime on and I always pay attention to the beeps when I open a door or window - kind of a continuous walk-test.
So with that kind of a connector you can screw down your resistor then solder the other end to one lead (makes no diff which lead) and screw down the second lead directly to the sensor. Of course if the wire doesn't immediately dive into a hole where the resistor is thus hidden, you may want to put a short length of wire in there to move the resistor far enough away that it gets hidden in the window frame or door frame.
The important thing is use only 1 eol resistor per zone and put it at the end of the run. So if you have more than one sensor on a zone, just put the resistor at or near the last one.
And you are right about that stuff, but, I have windows in my house that I have never opened in the two years I have lived here. So, I would never know if one of them had a bad wire but for using eol resistors.
