macromark
I think we are talking about 2 different things. I'm not talking about the route setting that is automatically done by the controller. I'm referring to the new feature that allows the user to manually set the command route. In the example below, the Last Working Route shows the route to go through this path: nodes 1 > 5 > 64 > 15 (controller is node 1 and end node is 15).vc1234 said:The leviton VRUSB (?) installer USB "stick", vrc0p and openzwave even with the prev gen USB controllers could set routing for years. E.g. from the vrc0p application note:
[SIZE=10pt]Routes (RO): [/SIZE][SIZE=10pt]To provide routing slaves with valid routes (when nodes can’t reach each other directly) “RO” command is used. Routing slave can have up to 5 nodes assign return routes. When adding new routes, it is recommended to delete all existing routes first. [/SIZE]
[SIZE=10pt]>RO2,0; delete all routes for the routing slave node 2. >RO2,10; setup up to 4 valid routes for node 2 to node 10. [/SIZE]
[SIZE=10pt]"[/SIZE]
So, nothing new here.
In our software, you can manually change the route to something else using the "Set Route" field.
In my system, the controller assigned a route to my lock that actually used a plug-in module in my shed... a crazy route! I manually modified the route using nodes that were neighbors inside my home instead. That's what I'm referring to. If you want to set the route (specifically), that's a new 500 series chip feature.
